Agile said:BG do a "safety check" which involves a flue gas analysis and takes less than 10 minutes. If the CO/CO² ratio is below 0.004 they dont even take the cover off !
Soggy_weetabix said:I would charge £59.50 for a Combi service.
Things checked...
Gas Pressure (c/h and h/w)
Hot water flow rate
Emmisions (sic probably) This includes flame picture obviously
Case seals
System pressure hot and cold
Ensure filling loop is disconnected
Fuse amperage
Burner removed and cleaned.
Pressure switch tubes.
An overall visual inspection of any leaks / potential leaks (ie crusted over)
Surely that is a basic service?
David
Gasguru said:Plus
inspect and check the effectiveness of the flue (including roof spaces etc)
test safety devices fitted
calculate and check any required ventillation for appliance
and
meter control valve working ok
working pressure at meter
tightness of gas installation
and
visual/spilage checks on all other appliances
and if applicable issue a Not to Current Standards form to cover ones a**e
