Boiler setting
29 Apr 2011
Due to my condition (some may, some may not know: //www.diynot.com/forums/viewtopic.php?t=378796&start=0 ) I need a constant heat rather than a quick blast of heat to get the room up to temperature.
Is it better to have the boiler set for the heating temperature to be lower?
It is currently set midway at 3 out of 6. WB Greenstar 24i Junior.
Room stat set at 20°c.
TRV set at 6 (Drayton).
Remember, I'm only a lowly ex counterboy.
It is more efficient for the boiler to be delivering a lower flow temperature as long as that keeps the room warm enough.
Of course better still to have weather compensation.
The Worcester unit is very good indeed although I cannot be certain that it is compatible with your model but it probably is.
Tony
How very charitable of you.
Confirms our suspicions of you being a rather nasty person. Charnwood has been a very popular and helpful part of this forum for much longer than this iteration of your personality disorder.
Charnwood, it depends on the size of the rads, the heatloss of the rooms and the temperature you are trying to achieve.
Get yourself a wrap around pipe stat and put it on the flow pipe. Get the boiler set to about 60 and see how things go. Best to try and compare different temperatures whilst the outside temperature is still fairly constant. You might find that much below 60, and things won't was up enough.
Chantelle, I thought we'd agreed to keep out of each others way previously. ;)
My condition is posted in General Discussion and generated 7 pages of posts, so there are some charitable people on these forums.
Thanks for your comments, anyway.
Thanks Tony and Dan.
My chair is roughly 2 feet from the radiator. when the heat kicks in I get 'blasted' with radiant heat, but - even though the room is up to temperature - when the rad is cooling/cold, because the radiant heat is no more I start to feel a chill.
Just a thought Chantelle, an old maxim - if you can't say anything positive then don't say anything at all.
I hope for your sake that if you are ever unfortunate enough to fall ill then you find you are surrounded by people with a more supportive attitude than you.
How about fitting a programmable room stat, so you can have setback temps to suit your needs?
A lower rad temperature may well make things more comfortable - trying to simulate ufh in a way, on for longer but lower. A tricky balance when taking the rest of the house into account.
Do you have problems regulating your body temperature in general? I would set the trv to the correct level for you, lower the boiler stat until you get the right balance.
A pity your boiler can't take weather comp, as it may have made it easier to maintain that sweet point.
That implies to me that you need the boiler on all the time with a low flow temperature.
Try setting to 60 C for a start.
I still strongly recommend the Worcester weather compensation. As you presumably know it varies the rad temp according to the amount of heat needed to give the set temperature as calculated by considering the outside temp.
Tony
I fitted a Honeywell CMT907 a while back - without landlord's permission (local authority property). They then replaced the heating system, the controls being a right BOS! A Danfoss manual thermostat and separate timer. The timer being independent from the stat means having to alter temps manually, there are only 3 time zones.
I still have the 907 so might seek proper permission this time.
Although, I'm fairly certain what the answer will be! :rolleyes:
Sounds about right. Something that will keep a roughly constant low-20s temperature to cater for both me and Mrs neshperson.
