Hi - I'm hoping that someone can help me.
I have a Vaillant Eco-Tech sealed system boiler which was installed in 2013. It runs both hot water and CH. There are three heating zones: one wired Honeywell DT90E thermostat and two wireless Honeywell DT92E thermostats. And a Honeywell programmer.
For some reason the boiler never seems to shut-down the CH when the programmer tells it to. For example, this evening, I put the CH on for 1 hour at about 6pm - the programmer switched off at 7pm, but the boiler was still heating the rads until 7.30pm when I eventually clicked the temperate down a degree on one on the thermostats - only then did the boiler shut-down. It would have shut-down eventually, it always does but I can't seem to find a pattern as to how long it normally takes but sometime it's well over an hour over the programmed time.
If I have to I'll get someone out (as I'm only a DIY'er) but keen to sort it out myself if it's simple to do so.
Many thanks.
Many thanks.
