fires up in the same way as if a hot tap was turned on and off
I might be way out here.
But if the shower mixer valve has gone . When you open a cold tap it draws the hot water through the shower valve. This in turn fires up the boiler. It might just be a fluke that its started since you have had some work carried out . It might be worth checking out
