boiler starts up then goes to red light ,pls help
3 Feb 2008
Yorkshire
hi there
my main concern is that the engineer has said that i needs a new pcb board and im worried that im getting ripped off as i have have just paid him £90 for e censor replacing i think
it started with the pressure . when i got that upto the 1.5 . the boiler wouldnt start @ all . i called out engineer he replace two little parts @ £20 each . it got working again , hot water fine but the central heating just kept stopping and going on red light . i have had one week and now it just goes onto red light when i turn on or reset .
when it starts up you can hear things get going , fan and so on but then fails and goes to red light . its a ferroli falcon combi boiler
all advice much appreciated
Common faults on these are the thermistors (temperature sensors)...appears they have been replaced. The water pressure switch appears to have been replaced...perhaps it was blocked.
Does the boiler red light come on as soon as you request heating? or does the boiler get very hot (maybe very noisy) and then shutdown with the red light? This would indicate overheating due to poor flow (isolating valves closed/rad valves closed) or failed pump.
If the hot water is still working you can probably rule out the other common faults.....broken venturi/pitot tubes, APS, incorrect flue restrictor rings, incorrect position of ignition and sense electrodes, incorrect ignition burner pressure. If these have been checked and are ok then pcb is normally next. I've changed many.
hi there , thanks for the response much appreciated
yes . it comes on automatically on both i cant have heating nor hot water
or does the boiler get very hot (maybe very noisy) and then shutdown with the red light? .
it did this for about a week and then went straight to the red light as in th e first question .
what is the next step ? and a new pcb board wouldnt that be the last option and if so how much are they ?
ad
If all the other checks have been done then it comes down to the board. Not sure if it's identical to the Modenas but they are around £150 - £190.
They also need setting up - ie not plug and play.
