Good Day,
I am wondering if you could point me in the right direction of my potential issue.
Complete newbie to this and to the forum so thanks in advance for any help / guidance.
Setup:
1/I have a boiler, along with timer dial in the kitchen.
2/Cylinder / Tank in hallway under stairs.
3/Theromostat for CH - On side of stairs.
Equipment'
Boiler : Ideal iCOS HE12
Cylinder / Tank - Range Tribune He
Issue :
Over the last 24hours my system now seems to be constantly 'on' even though I have not set it on via timer.
The issue remains even when I switch the timer off.
By constantly 'on' I can here my tank constantly making a lot of noise as if I have placed hot water or CH on.
I can 100% confirm this happens even when switched off.
Central heating is not on although their is noise so I assume it is the water element which remains firing in the cylinder / tank setup?
I am a complete novice to this but I can notice pipes remain hot and the pump attached next to cylinder / tank looks to be vibrating.
When looking at the boiler in kitchen, it seems to be set to C and boiler ignition switches between flashing and static light / on.
If I switch off the boiler in the kitchen at the wall all turns off successfully but this has been the only fix.
Any thoughts or guidance would be greatly appreciated.
Sorry if I should provide more information, if needed please advise.
Setup:
Equipment'
Issue :
