BOILER TURNING OFF WHEN I RUN HOT WATER
kaz
1 Feb 2004
I HAVE A COMBI BOILER AND WHEN I RUN THE HOT TAP IS CAUSING THE BOILER TO GO OFF I THEN HAVE TO PRESS THE RESET BUTTON I WOULD BE GRATEFULL IF SOMEONE COULD GIVE ME AN IDEA AS TO WHAT IS WRONG THANKS.
More information required - see the post at the top of the forum. Without it you will get bad guesses and little help.
AND STOP SHOUTING.
Does water come out of the hot tap ? What is the flow like ? Does the CH work normally until the boiler locks out when you call for HW?
sorry for shouting yes hot water comes out of the tap just for a few seconds then starts to run cold thats when the boiler has cut out it mainly does it when heating is on at the same time.
you are being politely asked to answer a few questions by replying here, the questions are here
its a biasi 24 and is 3yrs old its been nothing but trouble
