Boiler turning on with cold tap usage
9 Mar 2023
We are getting our loft converted and plumbers have been in to fit pipes that go up into the loft and I have noticed the following happening since:
Boiler turning on when cold tap is used. (This doesn't always happen, its infrequent).
Boiler - Vaillant ecoTEC plus 824 R1
Symbols appearing:
Flame - Burner On
Circle - Internal Loop is Running
Timer - Gas valve is activated
Annoyingly the plumbers have just been back round to look and it isn't happening but it did last night when I flagged to the loft company owner.
Thanks,
Nathan
Is it the burner actually firing up and staying on for a while or just momentary bringing pump and fan on
It’s just momentary.
Run the cold, turn it off, then it fires up for a few seconds and the symbols in my above post come on then go off.
I don’t recall this happening until the plumbers did pipe work to go up into the loft so wondering what has changed and what needs doing.
If they have just extended pipework without any other alteration then its possibly just some trapped air in a leg , if they have altered it then its probably a dead leg and as bod says shock arrestor should stop it
No idea what mixers are or how to find out.
The type of taps - separate hot and cold or a single tap (monobloc) or a deck mixer that mixes the hot and cold. If you have a dead leg in the system get it removed rather than fitting a shock arrestor
As far as I am aware they have just extended the pipe work up into the loft.
Would bleeding the radiators resolve it ?
This has been fitted in the loft but not used yet as bathroom suite isn’t in.
no its in the actual pipework to taps etc not the rads could well be air in new shower supply pipes run shower into a bucket for a bit to clear any air
If this is the issue / resolution. Would it resolve itself when everything is installed and I can turn the taps / shower on?
According to Vaillant the code that runs on my boiler after cold water tap used is “pump overrun following a hot water demand”
