I had a Valliant ECOTEC 831 boiler installed 2 years ago. At the 1 year service the boiler man said the appliance was under gassed. The pressure at the meter was 20.4mb but when all appliances (I also have a gas hob) are in operation the pressure at the boiler is 14mb.
The boiler guy put an AT RISK notice on the boiler and turned it off.
He said I should increase the size of the pipes, the problem is that the boiler is quite far from the meter and runs almost exclusively underground or under the floor. There is a small section exposed about halfway between the meter and the boiler so at best I can 'easily' replace about 2-3 meters. But I am not sure this will help much.
Looking at the commissioning checklist the engineer noted the gas rate was 3.18. Where it refers to pressure he made a note (which I can't quite make out) that looks like it says F/SET or P/SET but he didn't record the pressure.
I have a few questions and hope you guys can help me.
1. Is it illegal to continue using the boiler if it is AT RISK?
2. Should the engineer that installed the boiler have checked (and fixed) the gas supply? If so do I have any legal recourse?
3. Is there anything else I can do that would avoid me having to rip up the floor boards to replace the pipes?
Thanks!
Thanks!
