Boiler ventilation
10 Apr 2003
Gloucestershire
my boiler manual says cooling ventilation is required and should refer to BS 5440-2 as my boiler is enclosed in a downstairs cupboard.
the vent is in the suspended timber floor and there is air bricks around the house.
could the vent be through the cupboard door instead of to the outside?
(as its a bit of a chilly draught coming up through the vent !)
cheers
andy
This is a room sealed boiler which does not need any ventilation to the outside!
If you must put in inside a cupboard or compartment then it needs adequate ventilation.
The best solution usually found when its in a range of wall cupboards is to have an open bottom and top and 30 mm to laft, right and front of the boiler.
If you really must put it in a fully enclosed cupboard the it needs vents into the room above and below the boiler.
What exactly do you have in mind?
Tony
Tony
the boiler was already in the cupboard and the vent was in the wooden suspended floor (about 150x150mm) but cus the underfloor is cold you get a draught coming up. i was thinking of closing this off and putting a vent in the cupboard door.
just wondered if this was ok?
You can close the floor vent.
What is needed at the boiler depends on how its fitted.
Its been like that ever since it was fitted!
Can you post some pictures of the boiler and where it is and particularly taken from above and below?
Tony
