- Joined
- 16 Nov 2006
- Messages
- 22
- Reaction score
- 0
- Country
Hi, its my first post on here
I've got an annoying problem with my oil boiler which has manifested itself within ithe last couple of days.
First off, its a Beta oil boiler with an Ecoflam Monoflame Minor burner inside. The whole thing is 10 years old, but has never been any trouble apart from having to have a new motor starter capacitor, oil pump and hose earlier this year. Its not a combi boiler, but heats my central heating rads and hot water tank.
Two days ago I was awoken by what sounded like a jet engine spooling up in my kitchen as the boiler fired up. What seems to be happening is that when the boiler fires up from stone cold, it is making a loud whine which is echoing around inside the boiler casing. When my boiler starts up it runs for a few seconds without any oil feed to pre-purge the system. This whine is there right from the start - not just when the boiler actually ignites.
My hot water pump is in the airing cupboard on an adjacent wall. This also runs during the pre-purge but the noise does not seem to be coming from there. It definately sounds like it is originating in the boiler or burner.
I'm a mechanical engineer by trade and to me it sounds like maybe a bearing in the motor or fan has worn out. Alternatively something might have come slightly loose inside the boiler and is vibrating ata high frequency, and the boiler casing is amplifying the noise. Incidentally it sounds just as bad with the front of the boiler on or off.
One final vital bit of info: As the boiler warms up the noise dies off, until after about 10 minutes you cannot hear it at all. Let the boiler cool down again and hey presto - its back.
Any ideas?
Any ideas?
