- Joined
- 15 Sep 2016
- Messages
- 9
- Reaction score
- 0
- Country
I have a Heatline Condense Combi Boiler.
I have had it set to summer settings (tap water heating only) for a few months and had no problems.
I needed to heat my radiators the other day and switched the setting to winter (radiators & taps).
This appeared to work OK but after I was finished with my radiators I switched the setting back to summer which is when my problems began.
I ran a hot bath which was lukewarm/cool and went to look at the boiler, the pilot light was off.
I switched the setting back to winter and the pilot light ignited, some of the display LED's lit up and I had hot tap water.
I switched it back to summer and the pilot light went out, as did the LED's (apart from the green one that indicates ON) and the hot water stopped again.
Now, if I want a hot bath I have to turn on the radiators to ignite the flame so I can warm up the tap water, but the pressure gauge needle shows between two and three during this time (I'm not sure it should be that high?).
Once I've run my bath I can switch the settings back to summer and the radiators will cool down again and the gauge will reset back to between one and two.
I have attached two pictures of when I have the settings on summer and when I have them on winter. You can see the difference in the pressure gauge and the LED's with each setting.
Any advice on how to get hot water without switching on the radiators would be greatly appreciated, thanks in advance.
