Hi guys just wanted to check out what cables you use on your boiler wiring, As per regs it should be in solid core because its fixed wiring but interested in what configs you use. Ie multi core flex vs 3x t/e etc but especially what you would use say on a pump over run which has to go back to the boiler as apposed to the wiring centre, and wiring centre is in another room of house, and would you use flex for this ? most pumps are wired in flex?? or would you t/e from boiler then jb then flex to pump?
look forward to your comments guys
