I have a problem I need to fix so please help. The boiler is an HRM Wallstar burning 28 second RBO. It runs the heating using a room thermostat and Grundfos Selectric circulating pump in the airing cupboard upstairs and a Honeywell Three way motorised valve controlling water for heating/ gravity hot water. It has a water cylinder upstairs with a Honeywell T70 cylinder thermostat strapped on the side. The timer unit downstairs is a Potterton EP3002. I discovered the boiler had turned itself off and operated the EP3002 on/off slide and when I turned them both back on again the boiler fired and ran for about an hour then turned itself off again. When I turned the heating and water slides off again and then turned the heating on the boiler ran constantly and the house got boiling hot and ignored the room stat. Only turning the on-boiler dial down cooled it down and obviously there was no hot water. I bought a new EP3002 and swapped the new front over (but not the new backplate) and this did not fix it. I changed the powerhead of the three way valve fitting a 4000-3916-003 replacement powerhead but not the valve itself. The boiler fired and ran for a couple of hours but I checked the 3 way valve and found it was operating constantly back and forward. I noticed the cylinder was now hot. I opened the box containing the wiring centre and ,with the power to the EP3002 turned off , there was still power flowing through the single orange wire aswell as the single white wire. I thus decided the cylinder stat was faulty and replaced it with a Honeywell T55 set at 60 degrees C. The valve has stopped constantly operating back and forwards. The boiler turned on and ran but kept turning off and then reigniting. The boiler now fires, runs for a while but then shuts down the orange light. Turning the water slide off on the EP allows the boiler to run and heat the house. Nothing has been changed before the problems began although I moved/disturbed the EP 3002 which is not fixed to the wall but resting on top of the boiler to get to an aerial wire behind it. This morning I found that the boiler had again turned itself off. When I turned the room stat up it fired the boiler. The room stat clicks ok. I had left the hot water slide position at off. I don't know whether it is my imagination but it seems to be ok until it gets up to temperature andthen things start to turn off. Any help would be greatly appreciated.
