Boiler
18 Sep 2010
Hi new to this my boiler worcester 24i keeps on losing pressure when the water is turned on keeps going hot and cold I filled it up to one the first green can anyone tell me if it's safe to fill it to 1.5 so when the pressure goes down i've still got hot water?
Seems like you have a leak somewhere! This would be more beneficial to you if it were posted in the plumbing and central heating section.
probably the pressure vessel, you can either replace the internal one (they can be quite pricey, maybe £100) or fit a external one to the heating pipework.
If none of this makes any sense, then you probably need a plumber.
Thanks toasty will do that if I can't sort it out
thanks again
