Hello guys,
Got a new problem. Called in a gas safe plumber to replace the flow switch on the Ideal Response boiler.
As soon as he started closing the nut on the DHW inlet pipe and the Central heating pipe, they started to leak a bit. The guy stopped and said due to valves being very old and not moved since a long time, it would not be wise to go any further with the work.
He put everything back together and tried to put the screw type nuts back to
original position at the bottom for the DHW inlet and Central heating flow feeds.
But the problem is that there is still a bit of leak from these two nuts (like one drop every few minutes). There was no leak before this so any idea how this can be sorted without spending on new valves which doesn't make sense for an old boiler. I would not like to blame the guy as I don't think he did anything wrong as I was watching as he was doing.
How can I fix this leak please? Is this kind of leak normal and is it true we might break more things if we try and go ahead to change the flow switch?
Thanks in advance.
Thanks in advance.
