I have 2 Sanier Duval Thema F's, one does HW one does CH. The CH boiler seems to be leaking a little when its cold, it dumps enough water to drop the pressure by 1/8 of a bar. When the boiler is up and running there are not leaks. Generally both boilers work 100% ok with no other problems. Both were serviced maybe 12-16 months ago.
Just wondering if it's possible the cold weather is causing the leak in a possibility poor/weak seal and when the boiler is running, and things expand with the heat, the seal is improved.
I haven't taken the outer casing of the boiler as yet to see exactly where the water is coming from, that would be my next step.
make sense, any suggestions on other causes.
Ewan
Ewan
