Hi all
I'm looking for some advice (aren't we all!) with regards my heating issue.
The problem is the store (Boliermate 2000) never gets upto temp because the boiler (Potterton Suprima 40l) goes into anti cycle mode believing the boiler temp control is satisfied. However the store is not satisfied and so continuously calls for heat. The end result being short 30 second burns with 5 minute anti-cycle waits inbetween.
Fixes tried so far
Boiler temp control set to max
Boiler serviced - thermistor replaced
Store temp replaced - all sensors working
Pumps removed circulation checked
I know the boiler is capable of heating the water to temperature hot enough to satisfy the store (74-77C) as the temp of the water being delivered to store has been measured as 79C. It just doesn't seem able to deliver this amount of heat in sufficient quantity to heat the entire volume of water stored.
Should the bolier switch off immediatley when 79C is reached or should it deliver this heat for a few minutes?
Any suggestions and advice welcome
Fixes tried so far
