try jamming something inside it and gently turn it anticlockwise, do it gently and carefully and stop if you think the plasterbord is going to damage - I don't truly know what it is but guessing it is one of these drywall fittings - you can easily make a mess taking these things out.Looks similar. The one in my wall has V shaped cut outs on the rim
Just smack it through. Or cut out.
I normally smack through.
PVA hole ( wood glue will do as PVA)
Fill.
Sand
Paint
No other way to remove , it’s crimped behind the plasterboard.You can use an electric driver to spin it till it snaps and fall inside but still same size hole.Why do that? It might be a 10mm hole, If you smack it through it could become a 16mm hole, or worse.
