Bolt only threaded near head?
17 May 2013
Does anyone know if you can buy the opposite of this:
As in a threaded section near the head, smooth at the tip?
Like a kind of combination bolt/dowel... I want to put a through two pieces of wood, securely fastened into the first but able to move in the second.
I had thought about a metal rod acting as a dowel with one hole snug and the other a bit loose, but then how could I ever remove it - the top won't be accessible.
fully threaded bolt black marker where the thread needs to stop last 15mm in a battery drill chuck
file /emery paper /grinding wheel
Sex bolts involve a male and female part that would mate
You could use a bolt that had a thread all the way along and put it in a drill press/lathe and use a file or machine off the first portion of the thread? If I was doing it I would first add a nut onto the bolt to reform the thread end
I never heard of those and was nervous to Google it ;) very interesting but in my case the 2nd piece of wood don't be drilled all the way through to reach the other side.
Filing a bit sounds it might be simplest.
I can't decide if the thread matters or I'm just being a bit anal. I would like the retaining hole as small as possible without any chance of it binding so I thought a smooth rod might work better?
thinking about it more get a bolt 20-25mm longer than you need
then as above and then cut off the extra as that much easier than abrading the end thread :D
That's a handy tip. I don't have a bench drill or grinder only a hand drill and a vise and various abrasives... To avoid doing a shoddy job, any more tips the best way to do it?
