I've done some plumbing work recently, without considering the implications this may have on bonding. I've read a few things and only really become more confused. There are two main areas of concern that I have.
1. A resin sink has been replaced with stainless steel. The (metal) tap is now connected to the (copper) plumbing with flexible hoses where before it was soldered directly. The sink has a macerator installed on the half bowl. The wastes are all plastic.
2. A pipe running to an outside tap has been interrupted by a plastic fitting between the bonding point and the (metal) outside tap. The pipe is not buried in the ground at any point, the tap is on a brick wall in a paved area.
My understanding is that I don't need to bond anything (indeed, the sink isn't fitted with any provision to bond), but someone has previously bonded just about everything in sight so I'm not too sure.
