bonding on top of easifill?
28 Apr 2021
I’m replastering a stair winder, having hacked off some bits and built up other areas with bonding, there are some areas that I initially used easifill on that I’d like to add another inch or so to. Can I apply bonding over the easifill, or should just build up easifill layers slowly? Or should I hack off the easifill and start over again with bonding?
I'd gouge out most of the easyfil, bond onto whatever is solid underneath, and then easyfil over the top.
Easyfil isn't very strong so i'd be nervous of using it as a substrate for bonding.
