can you please explain what you mean by that to someone like moi who doesn't speak plastering? Thanksput level/plumb screeds on the wall
to make sure your walls are level when you float put a dab of render at the top same with the bottom you then infill the gap between the dabs with more render using a level , then do same further along wall the width of your straight edge will do , let screeds firm up a bit then rule off them for a straight wall, also if you have a door frame or beads on window reveals you could rule off those tocan you please explain what you mean by that to someone like moi who doesn't speak plastering? Thanksput level/plumb screeds on the wall
