Hi folks - I want to cover a hallway wall with ply instead of plasterboard, as it is always being crashed into and dented. I plan to cover and paint the plywood to get a decent finish. The wall an outside facing wall, so I put some foil covered celotex against it to insulate. I now want to bond 9mm ply to it, but nnot sure what to use? Instant grab adhesive, foam fxing adhesive, wood glue, pva? Any ideas?
Does the ply need sealing first, in order for the glue to bond to it? The foil is non porous, so will I get a good join? I do plan on putting a few frame fixers just to be doubly sure it doesn't come away through the wall. It will also keep the celotex behind the ply tight against the wall.
