About a year ago I replaced an original fireplace with a wood burner. The walls were damp either side of the chimney breast to about 800mm high on one side and only 150mm on the other. The wall adjoins a neighbours property. The property is 1890 built
I hacked all the plaster off back to the brickwork and injected some dryzone cream as the DPM looks almost non existent. I then used a bonding coat with a top coat of skim. In all this time (the walls that are facing the room) only one side has nearly dried out completely with the other still damp and a lot of salts/tide marks still showing. I was originally concerned that the damp was bridging at the floor so left about 30mm. A few months ago I raised this to about 100mm which although has improved the drying process slightly, it has still not thouroughly dried out.
My Mrs is keen for the wallpaper to go up but any ideas as to how I can cure the damp first. My neighbour says she has no damp issues on her side but I am aware that her chimney has been blocked which is directly the other side to where our damp is! This is why I used dryzone which I thought caused a barrier.
Should I perhaps inject the Dryzone higher up the wall?
Should I have used sand and cement instead of Bonding?
