I am installing a shower pump and need a wee bit of guidance. The cold comes from the tank in the loft and feeds the basin, bath/shower and toilet in that order. Can I intstall the pump before the basin and put the toilet on a separate feed from the tank or can I just install the pump with the toilet and what would be the effects on the toilet? Also what's the best way to connect the hot from the cylinder? I've been told to use an Essex Flange which I presume would just tee off from the feed/vent into the pump. Thanks in advance,
Martin
Martin
