Hi, everyone, first post so apologies in advance!
Sort of reverse problem to most posts about accumulator tanks, in that we will have a borehole pump supplying DCW to house, tested flow rate is 50ltrs/ min via 25mm MDPE pipe. As water has previously tested positive for bacteria will be installing UV sterilisation unit (rated @ 48ltrs/ min) after primary inline filters. The question is twofold, is there a way to regulate pressure to outlets and have some reserve capacity(accumulator tank?) AND switch pump on/off via some kind of high/low pressure switch to prevent pump cycling? BTW the pump only has simple on/off control(i.e. no built in pressure switch).
All the above only applies to cold water only.
Thanks for any suggestions
