Sadly my phone is complaining of no memory so unable to take pics today.
I've been out assisting another to find out why the New CU fitted in a rental property [by sparks sent in by agent] "Doesn't work".
For a start we found the customer with no working power apart from shower and the CU has not been changed but a couple of RCD's have been added to the 30yo plastic Hagar to feed 4&5 circuits each.
total of 11 red wires from 3/0.029" & 1mm² to 10mm² however neutral blacks consist of 1x 10mm² [shower T&E], 1x 1mm² [outside light T&E] & 2x [estimated] 7/0.044" arranged as ring with lots of original junction boxes I'd describe as an oversized Besa about 3½-4" diameter containing a single brass block with 9 screws, a bit like these:
but 3 holes each side which don't go right through, 2 screws one side and one the other side.
I have no idea what the heck was going through the mind of the person tasked to do the EICR and changes, but he'd simply put each end of the neutral ring into an RCD along with another neutral wire, something like this.
And of course installations of this age relied on the split tube for earth.
