Have just come back from my hols my boiler is playing up it will allow you to run hot water for a while the cuts out with the flashing red light going once reset it some times lets you restart and sometimes you have to wait 10/15 minutes before it will let you run hot water, it tends to go out after 10 mins or so, I have checked the inline filter by the turbine and the dhw pressure switch at the heat exchanger both these seem ok. the fan runs on demand, did try central heating but didn't run it for long although it did fire up, any ideas,? its only about three/four years old, had 2 pumps and a thremocouple and a dhw pressure replaced by bosch, is this the friday boiler? fix or replace?
