BOSCH AQUATAK 115 Pressure Washer - Switch on/DEAD/nowt...
1 May 2014
Liverpool
...completely dead when I switch it on. I''ve checked the fuse, mains cable, on/off switch, all are good, but from there i'm a bit stuck as to what to look at next.
I've looked on You Tube and i've found a pdf of the illustration diagram on google but really found nothing to help, so wondered if anyone had dealt with a similar problem with their pressure washer in the past?
It was bought four years ago and seems a waste to me to just bin it.
Would appreciate any help thanks,
Ian
Ian, just check that there isn't another overload switch on the bottom, will you.....I'm pretty sure the 125 model has - maybe yours is the same.
John :)
thanks john, there is a switch at the bottom as you say, i'll take a look at it today :D ian
