It gets to the end of the wash cycle, does not drain, spin light flashes. There are no blockages, the pump is working, if I manually take the water out I can put it on a rinse cycle and it works perfect, rinses, drains and spins. the pressure hose is not blocked, not restricted ...... it does not matter which wash cycle you put it on, it stops after washing as above.... help !!!
