Bosch Classixx 1200 Express trips mains mid cycle
12 Apr 2011
Nottinghamshire
Looking for a bit of advice on our washing machine.
It's a Bosch Classixx 1200 Express (WAE24162UK) and until now has been faultless in operation. However last Sunday it began to trip the mains about 10 minutes into a cycle.
The main panel lights up, the drain pump seems to work, the motor spins (though I haven't been able to see it do high speeds due to the point it cuts off) and the door interlock works.
I took some advice from the web and pulled the machine out to inspect key parts.
-The heating element was removed and showed continuity both in and out of water (bucket test).
-The thermistor? seemed to check out OK too
-The drain pump was removed and cleaned. I found a wet grey paste which felt like grease inside the drum holding the motor armature. Having never seen one new I don't know if this is normal as it seems like a sealed unit.
-The main motor was removed. The brushes are around an inch long and worn evenly.
I've ordered a new drain pump, carbon brushes and heater element as they aren't expensive and all these parts are easy to replace.
Can anyone recommend any other checks on this machine? I wondered if it would be possible to disconnect each component and run the machine to eliminate the issue.
The bucket test ? Did you test for earth leakage between element terminals and the metal sheath of the element ?.
Is it the RCD that is tripping ( due to earth leakage ) or the MCB ( due to current overload ) ?
Cancel the pump and brushes they won't be causing trip switch to trip.
It's most likely the heating element, because it doesn't get switched on until the wash cycle has been going for 10 minutes anyway.
