Can anybody help? A neighbour has a Bosch Classixx Dishwasher SRS43C32GB/01 Type SD1301B with a leaking drain pipe. Pipe has a small cut in it which I reckon has been there from Day 1. Machine is about 5 years old but has been only lightly used. Anyway, I have got the correct replacement hose but I'm jiggered if I can find out how to get in to the blasted thing. Spent several hours today with it on its side. Existing pipe disappears inside at back but no obvious means of access for replacement. The dishwasher base is a heavy plastic moulding but I couldn't discover how to get inside. Got bottom front skirt off and sheet metal panel behind. This gave access to two torx screws at front which seem to attach the base to body but could not find any equivalent fixings at the back of the base.
I would be very grateful for any help. Thanks.
PS The existing drain pipe is not really suitable for repair as it has a tight concertina profile which does not lend itself to a patch-type repair.
