Bosch Classixx dishwasher is suddenly not cleaning.
N
Niesert
Suddenly this dishwasher is leaving the dishes dirty. Salt & rinsing fluid are full and the soap is the same. Filters are clean and water seems to run as usual... Any suggestions of a solution?
First check to see if the spray arms are blocked. If you post again note the "E number" on the door lip.
Yes, that's it. Can you hear (or observe) the wash motor running? If it just "hums" I would suspect a defective motor capacitor or perhaps even a jammed impellor. If the motor runs does any water come out of the spray arms? Do the spray arms rotate? (you can check this by setting them in a particular position, then run a program & open the door after a short while to see if there has been any movement). Many questions I know, but not being there you will have to be my eyes & ears.
If the machine is running "as normal" and you have eliminated blockages/leaks and pump problems then you should check if the machine is heating....or not
To help more you should post the full model code and FD numbers located on the door rim
Girlfriend had the same problem with the same machine. Turned out to be a piece of glass blocking the drain.
