Hi there. I was looking at this machine for a friend because there were a couple of inches of dirty water left in the bottom at the end of the wash. Took out the filters and cleaned - not too bad - and then removed the L-shaped piece that's held in with a Torx screw to have a look at the small horizontally mounted impeller (the pump-drain I think). Looked like it should have half a dozen or more blades, but only two were left, the rest had obviously sheared off. I'm guessing that this is the cause of the problem.
I'm about to order the spare part (0460) for this machine (version SRS53C02GB/28 ) from Bosch, but before I do, I wanted to ask if anyone knows how you actually go about replacing this part - the woman at Bosch spares didn't know. Is it straightforward?
Also, is there anything else that it might be worth looking at/checking while I'm replacing the part - I'm wondering whether the blades might have got lodged somewhere sensitive!
Thanks in advance
Thanks in advance
