Bosch Classixx Dishwasher Problem.
1 Feb 2010
Cambridgeshire
Hi my Bosch classixx slimline dishwasher has stopped heating the water & it takes twice as long to run& its not drying the stuff at the end,its around 5 years old?
cheers
nige.
you have 1 of 3 possibilities
could be something elese but is highly unlikely
1) faulty heating element
2) faulty thermostat
3) faulty PCB
PCB is likely to show burnt tracks if faulty
element can be tested with a meter tester , and can be accessed via removal of a side panel
thermostat is on the element housing looks like this
http://www.casaparts.co.uk/products/id-25080927
element is at the bottom of the picture , stat goes in the hole in the middle an looks like this
http://www.casaparts.co.uk/products/id-25080903
undo the t20 screws down the sides and top of the inside of the door
lower front panel will fall out , catch it or you might scratch it !!
the facia panel then needs to be gently eased out a little ( many wires )
pcb now exposed
, will have several multi pin connectors , take a photo of where all the wires go before removing
the plastic box contains the circuit board. have a look in here for any tiny black smokey bits which may expose evidence of a flash.
Hi yeh looks like the pcb can you buy that bit the number for the dishwasher is SRS43A02GB/08
cheers
nige.
Hi it looks like it was just a small hole so i put a bit of solder back in there & it seens to be working fine now so hopefully its sorted,thanks for all your help.
