Bosch Classixx dishwasher
11 May 2010
Gwent
My dishwasher does not appear to have the correct water pressure when washing. I have checked all pipes for kinks etc, but can find nothing wrong. The tablet doesn't dissolve completely and has even 'stuck' to the plates where it hasn't fallen through tidy from the dispensing drawer. The water sounds as if its 'dribbling' through the dishes rather than 'whooshing' - like the description? Any ideas?
Hi, if it's doing everything else i.e. taking in water, washing, heating, draining, then more than likely it's the upper and lower spray arms in the diswasher are blocked. There are a series of holes on each spray arm through which the water is sprayed onto the dishes. If these become blocked then it will not be able to wash effectively. Some of then come apart others you've got to use pipe cleaners or such and a lot of elbow. Hope this helps.
James
Possible for the circulation pump or capacitor to have failed as well.
First and easiest though is to check the spray arms as jmcjames said
