Bosch Classixxx 1200 WM Not Spinning
7 Dec 2011
Hopefully somebody can help me. I've been reading this forum trying to find a solution but nothing has worked so far.
Basically the Bosch washing machine has stopped switching to spin and then rinse on a regular wash cycle. I can manually set the machine to spin and then rinse at the end of the cycle and it works fine, but it just won't switch automatically.
First we opened the filter cap and some water came out but it didn't solve it. Then from reading here, I thought it might be the brushes so I took the motor off. The brushes were worn down quite a lot so I went and got some new ones and fitted them. Again, it didn't fix the problem.
It is strange, because the spin anr rinse cycles are working, but it just won't switch automatically to them as it used to. Any ideas?
Does it heat the water?
Post the E-number on the door sticker so we can pin down exactly which model you have.
Thanks for the reply. Yes, it still heats the water. It does everything except switch to the rinse/ spin cycles.
The E No. is: WF02466 GB107 FD 8410 600179.
Any help would be greatly appreciated. I really don't want to have to buy another washing machine as this one is largley fine except for one rather annoying glitch.
