hi guys,
so....
i have a bosch cold fill awasing machine - worked fine in my flat.
now i've given it to the parents as theirs has bitten the dust.
it;s plumbed in, connected to the cold feed - they actually have a cold and hot feed, and.... it wont take the water - in the same way as when i tried to start it at the flat with the water turned off.
if i connect it to the hot feed however, it works fine! - although i worry that will damage it so i'm not doing that.
any ideas? - could it be that the cold water pressure is too high? - if so what would be the likely cost of what is needed to reduce the pressure? - thanks!
so....
