Hi, I have an integrated SGV53E03GB/72 which fills to door level and then keeps pumping & filling. I think I can hear another pump trying to run but no water is coming out. I've stripped & cleaned what I can see from inside the machine but before I pull it out i'm wondering if there is more I can do. I blew down the hole feeding the bottom arm and got plenty of bubbles so I don't think there is a blockage. Feeling into the hole opposite the drain pump, I can feel what seems to be another pump impeller which turns reasonably OK. Any suggestions gratefully recieved.
Thank you.
Thank you.
