Bosch Dishwasher - insufficient water
C
cmother1
Our Bosch Dishwasher has developed a habit of pumping out too much water at key points in the wash cycle (there's only about half an inch left in the sump under the filter). The result of this is that there isn't enough water for the pump to drive the arms round so the plates don't get washed. The only remedy I've found is to open the door at strategic points in the cycle and chuck in 1.5 to 2 litres of water after which it's fine until the next next stage of the cycle. Has anyone else had this problem?
Next question: how do you get a Logixx apart? I can't see any obvious ways of getting into the "wet bits" in the bottom of the machine.
