- Joined
- 1 Nov 2004
- Messages
- 30
- Reaction score
- 0
- Country
Hi all,
Had a problem with my dishwasher (bosch classixx) where it would not finish washing and would run continually.
Removed the back and sides to investigate and found a pool of water in the base of the machine.
The machine was running continually as it had activated the anti flood device and continues to pump water out of the machine as a safety measure.
After a few more trial washes i can now see that the puddle of water is starting right under the centre of the machine. But the back and sides of the machine do not remove and there is very poor access from the sides due to the pump on the right and the various pipes on the left.
I suspect the leak could be where the pump connects to the bottom of the wash chamber or maybe where the impeller connects, but without better access its hard to tell, is there any common items that i should be looking at causing the leak, or an idea how to break the machine down futher to gain access to where the leak is coming from.
From the inside of the machine, under the grill there are 2 screws holding the sump to the bottom of the wash chamber but removing them allows no extra access.
I appologise for the long post, but i have tried to be as detailed as i can.
Any advice appreciated,
Dave
Dave
