Hi all,
Dishwasher is playing up. Makes all the appropriate noises but only a light splash of water comes out of the bottom spray arm. Remove the filters and there is not much water there. If you manually add a couple of litres, regular spray operation returns, so it's clearly underfilling.
I've stripped it down today. The fill solenoid operates fine, the drain pump is fine, the main pump runs ok.
None of the internal hoses are blocked, although i did clean a few out.
The pressure chamber was gunked up and the float was stuck. I've cleaned this out, put it back, and tested that the microswitch works as it should.
I took the dosing chamber / matrix out and refitted it. It appears to refill ok when reconnecting the appliance. There is some scuzz buildup in the top left corner, which appears to be part of the drain side of it, not the clean water side. I can't see that this therefore could be the cause of the problem - am I wrong?
What does the machine use to decide it's full? It appears to me that the float in the pressure chamber is for when the machine is OVER full and it kicks the drain pump into action. But what controls the fill volume normally? is it just a timed fill?
Could the fill valve be only partially opening and not allowing sufficient flow?
and thoughts are appreciated. i've never fiddled with a dishwasher before so it's all new to me.
thanks
slip
thanks
slip
