I have a Bosch dishwasher model SGS45E02GB/56 which has worked perfectly for three years. When I tried to turn it on last night there was absolutely nothing, no lights, no noise, nothing. I checked the fuse, socket etc but it made no difference.
When my wife turned it on ten minutes later it started fine and I assumed I'd done something wrong but it only ran for about ten minutes and then died with dirty water in it. Again no lights or noise.
This morning I took the top and sides off and had a poke around. All pipes were clear, the drain pump was clear, there was no water where it shouldn't be. Still no life. I wiggled the anti-flood float a couple of times and the drain pump sprang into life when I lifted the lever.
The machine is now running but I don't know if it's something I've done or whether it's an intermittent fault on the machine that has fixed itself.
Does anyone know if the anti-flood mechanism cuts the power completely like this and could cause the symptoms described? Or does this sound like a problem with the control module?
