- Joined
- 11 Mar 2019
- Messages
- 38
- Reaction score
- 0
- Country
I thought I'd found a cause, or at least a symptom, with my G1143sc dishwasher which usually stops soon after the cycle starts. The attached video shows the problem, water starts to fill, then it stops and a banging noise is heard:
I've kept the video short so it shows the fault happening only twice. The red Inlet / drain light flashes exactly six times, then a solid red light shows then this pattern repeats itself every 10 seconds. In the video, the banging noise can be heard at 1 second and 11 seconds. This repeats itself many times until either the machine somehow gets through it and works, or it stops completely.
I had thought I'd found a "solution". That is, before the machine started, I used a cup and turkey baster to remove all residual water; the drain sump by the non-return valve is always full after a complete wash cycle. Using this method, the machine worked fine. But now, the same issue repeats itself, even if I've previously emptied the drain sump.
I've seen suggestions that the non-return valve. So I await that part from UK Whitegoods and although I don't know if replacing the NRV will help as it shows no obvious sign of wear or worn rubbers. But I'll replace it anyway.
The impeller doesn't "spin" when flicked with my finger although it does move and click - presumably there is a kind of ratchet mechanism - but nevertheless it turns without much difficulty.
I've had two independent engineers who both appeared to fix the problem but only temporarily - without replacing any parts. And the fault has soon come back.
Any ideas on what I can try next would be much appreciated.
