Bosch dishwasher SGV 53E03 no water entering
27 Aug 2008
Surrey
My dishwasher does not fill with water, the pump runs and if I poor water in it drains away, does anyone have any ideas
Base is full of water activating anti flood or pressure chamber is blocked. Remove left side panel to inspect.
will do thank you, if it is flooded is there any kind of common reason why
I have taken the side off now and there was water in the bottom tray, I have removed this and the dishwasher is now working, I can't see any obvious leaks, is there anything that I should look out for
you may have a leaking seal usually the one by the circo motor (front right) or if the water was clear in the base look at rear inlet valve(back left)
