I have a Bosch sms40t32uk dishwasher. The initial problem was the unit would not drain, I discovered the drain pump cover loose in the sump which was probably the problem. However in disassembling the unit I seem have introduced a new problem and there is now apparently no power to the unit.
I have put a multimeter across both the door switch and power button and both are registering 240v but I push the power button and no lights come on at all. Is there a reset routine or switch and is there a test cycle for this machine?
Richard
Richard
