Good afternoon,
I have a Bosch SGS56E02GB/45 dishwasher which has recently started causing a hammering in the pipework when it fills.
The needle on the pressure gauge on the rising main jumps up and down in time with the noise.
I replaced the fill valve, but this has not solved the problem.
I then read that the impeller jug failing could also cause the same symptoms, so I bought one of those only to find my dishwasher doesn't have one, despite it being advertised as compatible (rookie error - should have opened it up first).
There haven't been any other changes in the plumbing in the house before/since the problem started, and there's a PRV on the supply limiting it to 3 bar.
Any ideas what I could try next please?
Thanks for any pointers.
