bosch dishwasher will not fill - internal leak code
28 Jun 2009
Warwickshire
Hi everyone,
got a problem with my Bosch sms32e02. When I switch it on, i can hear 3 clicks (from the control module, which is siemens by the way, Bosch and Siemens should be same products) and jammed motor sort of type noise, then, after pressing start switch, same 3 clicks and error code E23 is displayed. The service told me it is "internal leak fault", which is undestandeable because it happens even if the intake water pipe is not connected (the dishwasher has aquastop device and valve on intake pipe stays closed). I wonder if leaving it to get dry will help, in the meantime, anybody knows how to fix the problem? I have take off the side panels but will not attempt for the moment to go further, bottom of dishwasher seems dry. Thanks a lot.
