Bosch Dishwasher won't stop Can I do anything?
22 Nov 2013
Norfolk
Help!
My dishwasher circulation pump continues to run after the cycle has stopped. I have to manually turn off the machine to stop it.
I know it's not the drain pump as I can see that's OK when I look at the plastic water matrix on the left hand side of the machine.
The first time it happened I took out the control module. It looked fine but I re-soldered as many joints as I could. The fault then went away for about a month.
That time I removed two of the relays to look at them but they were sealed up so I put them back on the board. The problem went away for about a week.
I happened to be standing near the machine when the pump spontaneously started running again. The machine had finished a normal cycle and had completely cooled down by then.
I'm not sure what to do. could it be a relay? If so which one? Do I need a complete new module?
It's a Bosch Exxcel
SGS45E02GB/56
